Home > Maintenance & Mods (L322) > difference between engines in bmw745i and range rover 4.4 v8
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
Does anyone on here know what differences there are between the engines of the 2002 bmw 745i and the range rover v8 as the 745i power output is indicated as 245kW and 450Nm and range rover 210kW and 440Nm. The displacement of the 2 engines are exactly the same. Could the difference be because of differences in exhaust system, engine management system, or something else.
Post #124842 3rd Jun 2012 5:14pm
ems, cats, cams maybe, sump certainly, swirl flaps if they fit them to the petrol bmw engine..
The rr engine will be setup for mor low down torque i'd bet Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #124847 3rd Jun 2012 5:46pm
mjdronfield
I know the Land Rover installation has scavenger oil pumps, to ensure the oil is still picked up and circulated at the various extreme angles you can get a Range Rover to........
Possible different seals etc to help against water ingress and such like....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #124848 3rd Jun 2012 5:55pm
vnitos
The bm's output is 245kW@6100rpm and 450Nm@3600rpm whilst rr is 210kW@5400rpm and 440Nm@3600rpm - so torque for bmw is higher at same revs as rr whilst power is 35kW more for bmw t higher revs. Would like to explore how to get some of that power in the rr if the cost is not too exorbitant.
Thus far cats are removed and due to upgrade to 2006 front end had to put cone air filter in, so that part is covered.
Post #124851 3rd Jun 2012 6:15pm
