Home > General > Help . EAS error and stuck in Paris!
Stephen.Gazard
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
So I've been having problems with EAS errors, garage fitted new height sensor rear nearside and then discovered broken cable which was mended ....
Driven today from Bristol to Paris Disneyland ..... Just as reaching disneyland .... Air suspension error going round roundabout ....
Turned off and restarted cleared and then reappeared ....
Now at hotel put IID tool on and showing a "cross articulation" error ....
Thoughts and assistance appreciated ..... Stephen Gazard
Range Rover L405 LWB SVA Overfinch / Bespoke
Maserati GT 2017
Maserati Levante Trofeo
Mercedes SL63 AMG
Mercedes S500L
Post #124762 2nd Jun 2012 5:08pm
a cross articulation error points to a faulty height sensor which you have just replaced/mended.....check the wiring again... ... - .- -.
Post #124764 2nd Jun 2012 5:17pm
daveo
hi mate, had this error wen i first bought my car,the chap said it had been going on for months, read on one of the other sites to disconnect the batt for a good 15 mins and reset, it worked first time something to do with the error stuck in the memory, hope this helps.. just to mention it never came back..good luck. V8 facelift Range Rover Autobiography 22" wheels.
Post #124766 2nd Jun 2012 5:23pm
As above Stephen, agree with Daveo, disconnect battery for half hour or so... Failing that, you may find its just an error message and you may find it will work correctly for the duration of your travel's...
Craig Thumbs Up
Post #124767 2nd Jun 2012 5:47pm
Stephen.Gazard
Thanks guys ..... I've just put the IID tool in and found the rear left was seriously out of calibration .... Have redone calibration and will see if that was contributing ..... would kind of make sense as it would occur when hard cornering round a roundabout ....
Will see what tomorrow brings ...
Just can't believe Sytner clearly didn't recalibrate after fitting new sensor! Stephen Gazard
Maserati GT 2017
Mercedes SL63 AMG
Mercedes S500L
Post #124770 2nd Jun 2012 6:33pm
Doom and gloom post:
I got cross articulation error when I got a hole in my air bag Thumbs Up .
Post #124796 2nd Jun 2012 10:36pm
