![]() | Home > Duckworth Parts > couple of parts reqd |
Dan won't be back until Wednesday |
cookie42 Member Since: 09 Oct 2008 Location: preston Posts: 46 ![]() ![]() |
thanks , hopefully he will see this when he's back |
You are best fitting the stretchy rubber gaiters |
have you any links ? |
No but Google should help. Don't buy the glue together ones, they're s |
do you mean this sort ?
Give them a call and check it's for the L322 |
If they are front ones, you may be in for a pain in the arse getting the shaft out of the hub,,, Most corrode so much they have to be pressed out!!! Craig ![]() |
I use an air chisel with a blunt end to press the shaft out of the hub |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
PM your vehicle details, ideally the VIN You can paypal direct using - www.paypal.me/duckworthparts
pm'd |
