Home > Maintenance & Mods (L322) > Stuck in Lo Ratio |
edward.barry Member Since: 26 Aug 2011 Location: Cavan Posts: 37 |
Hi Folks
29th May 2012 7:26pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Possible it is transmission wind up, but not sure L322 can suffer that. If it is, reverse it a bit, then try again - OR, carefully lift a corner on a jack ....
29th May 2012 7:29pm |
Agree - also try neutral, no brakes. Or - do what I do - low to high on the move, get up to about 10 mph, neutral, re-engage. There is no need to stop to switch, up to ... gulp ... 60mph! *or* find a hill and roll down Land Rover Addict
29th May 2012 7:46pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
You should be able to hear/feel the motor engage/ disengage... Can you hear it trying to change? It does sound like it could have seized.. Lubrication required me thinks.. Previously..
29th May 2012 7:50pm |
Thanks Folks, got it, used the lo to hi method on the move, took a few attempts, had to push the swich pretty hard before I got the reassuring "bong", wondering if the switch it self might be little dodgy. Anyway, take the point on lubrication, will throw it in the air over the weekend and have a look. Where abouts underaneath should I attack with WD40, is it somewhere in the region of the gearbox? Thanks again, great supportive bunch on here. Regards ED 0-60 takes 5 and a half seconds...and about 17 gallons of fuel....
29th May 2012 8:13pm |
Use penetrating oil, not WD40 Land Rover Addict
29th May 2012 8:27pm |
Fair enough, thanks 0-60 takes 5 and a half seconds...and about 17 gallons of fuel....
29th May 2012 8:34pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
Not quite sure what you are going to lubricate?
29th May 2012 9:33pm |
No error messages came up, when it got "stuck" in lo ratio. I also have a Hawkeye and though I know its limitations it showed no errors. Will have a look at the switch over the weekend when I don't need the car. 0-60 takes 5 and a half seconds...and about 17 gallons of fuel....
30th May 2012 5:24pm |
