Home > Technical (L322) > Problem with ride height suspension |
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 |
Hi
6th Nov 2008 4:14pm |
I had that problem about three times twice i took it to the dealership and they told me it was a software issue . on the third time i called out LR ASSISTANCE and the engineer re - configured it via his laptop and his explanation was that because the RR has so many brains in it.
6th Nov 2008 5:28pm |
Larry Member Since: 03 Dec 2008 Location: East Midlands Posts: 262 |
My first post on this site, but might be able to help.
3rd Dec 2008 8:30am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
Thanks Larry, good to know. Discovery 4 HSE
3rd Dec 2008 12:13pm |
This problem has re-occurred , called out LR assistance who have came out and did exactly what Larry had mentioned with regard to the valve , the one that they re-placed it with has been modified , as i have been told by the Techician that this new part will solve this ongoing problem that happen's with the FFRR suspension........
23rd Dec 2008 12:53pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
hi mick do you know what the part is or a part no so we can find out eigher what it does or whether we all could replace it to make our lives so much more stress free onto no6 Range Rover
23rd Dec 2008 3:20pm |
Sorry fraid not ,the guy had it fitted in about 15 - 20 mins , a case of take out the spare wheel, black metal cover in place with 4 bolts undo bolts and take out, look for a small compressor valve roughly about an inch long thats screws into the pump and the other connects to a pipe , this is what causes the problem , the new modified part is slightly similar but has a very small hole in the side of it to stop it from clogging up.
23rd Dec 2008 6:00pm |
thanks mick i hope you find the info you need and im sure we could all benefit from your knowledge onto no6 Range Rover
23rd Dec 2008 8:48pm |
pyramid1235 Member Since: 25 Mar 2009 Location: Glossop Posts: 20 |
I had a problem with my suspension it kept bringing up "suspension fault" on the info display and turning the orange led off on the centre console when driving on the road it was more often than not if i went over a bump it would go to fault also it would not lower to access height to clear the fault i turned the ignition on and off which would allow me to change the height to off road but if i tried to go to access height it would start to go down then go straight up to extended mode and be very difficult to get back to normal height - after reading the post about the exhaust valve on the compressor i decided to take it apart and clean it out it was stuck solid in the closed position i eased it out and cleaned it up and freed off - now all faults cleared on suspension and all working as it should will go to access height no problems now at all thanks for the info!! |
30th Mar 2009 8:10pm |
KING OF THE ROAD Member Since: 06 Jan 2009 Location: UK Posts: 34 |
Had the same fault kept on saying "Suspension Fault" on the dashboard info display. Left it for a day and it dissappeared. But than back again the next day. Took it to the dealer and was told....... the valve on the compressor unit situated under the spare wheel needed to be replaced with a upgraded heavy duty one. Supposedly a very common fault. My car is still under warranty so nothng to pay!!
31st Mar 2009 12:53pm |
Recalls are 'black marks' as far as the car industry is concerned, even when the front driveshaft/diff problem was going on everywhere, they just introduced a customer 'programme' to make it seem they were doing us all a favour, rather than actually fixing a known problem part that was causing them loads of hassle. Discovery 4 HSE
31st Mar 2009 1:43pm |
Don't suppose you got a part number for the new valve? Is it on the invoice/paperwork? |
31st Mar 2009 1:53pm |
jm Member Since: 07 Dec 2008 Location: angus Posts: 16 |
I have just had the same problem
1st Apr 2009 4:07pm |
