Home > Maintenance & Mods (L322) > oil change |
So long as the oil meets LR spec it will be fine. It probably had a slight rattle on start-up before the oil was changed, only now you are listening for it. |
25th May 2012 11:30am |
dannyp15 Member Since: 21 Sep 2011 Location: essex Posts: 244 |
is 5w-30 ok as LR recommend 5w-40
25th May 2012 11:32am |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 |
Use what friend put in for a week or so to flush the engine then swop for correct grade Mine was a blue one! |
25th May 2012 12:30pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8488 |
Its a matter of which 5w-30 he used. Has to meet lr spex. There is nothing that can't be fixed with a hammer😜😜
25th May 2012 1:07pm |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 |
The variable valve timing system will "rattle" at startup sometimes; the oil drains back out of it. Takes a moment for it to pressurize. There's supposed to be an anti-drainback valve to prevent that; it fails sometimes. (this is a BWM engine issue) IF the oil meets LR specifications, you're fine. Ask him what oil he used, look it up. Oil viscosity is not the only determining factor. For my 2005 BMW engine, these oils are OK: Castrol Syntec European Formula 0W-30 Pennzoil Platinum European Formula Ultra 5W-30 Valvoline Synpower 5W-30 Mobil 1 Full Synthetic 0W-40 Different viscosities, but they all meet BMW's LL-01 specification (ACEA A3/B3). Viscosity is significant depending on the temperature range in which the vehicle will be operated. I use Mobil 1 0W-40. Only available in quarts, not larger sizes. That sucks. Read the manual, see what's OK. Decide based on that. Jim 2000 NAS HSE 2005 NAS HSE |
25th May 2012 8:25pm |
