Home > Technical (L322) > Glovebox lamp
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Glovebox lamp
56 plate RR Vogue (split glovebox) ... is there *supposed* to be a lamp in there? Handbook doesn't allude to changing one, but there is a fuse ..... <baffled> Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #123523 24th May 2012 9:10pm
jfb1977
England 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
On my 2007 (split glovebox) there's a bulb in the bottom half only. I know because I changed it today (and bloody fiddly it was too).
The easiest way to tell is when you open the lower half of the glove box, is there a small plastic rod sticking out just to the left (as you look at it) of the catch? It's a spring loaded thing that turns the bulb on and off as you open and shut the glove box. If that's there, then there should definitely be a bulb in there too!
Thumbs Up Past (too many to list, but a few favs)...
2007 Porsche 997 C2S Coupe
2007 FFRR 4.2 S/C
2012 Jag XKR 5.0 S/C
2014 Merc SL500 AMG 4.7 V8 BiTurbo (remapped to 560BHP)
2011 FFRR 4.4 TDV8 Vogue SE - Overfinch Conversion
2012 Porsche Cayenne Turbo
2018 AMG C63S Estate
2015 Mercedes GLE63S
2017 Maserati Levante Diesel
2017 Audi A6 Avant 3.0 Black Edition
Post #123547 24th May 2012 10:41pm
simon1233
bottom one has a lamp - I never realised that mine wasn't working, but when the LR tech was changing my navigation/entertainment screen they swapped the lamp switch over at the same time as apparently it was broken Thumbs Up
Post #123562 25th May 2012 6:08am
