![]() | Home > Technical (L322) > Why is my viscous fan on when it shouldn't be? |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
does it do it on lpg and petrol ? onto no6 Range Rover
ngb13 Member Since: 22 Jan 2010 Location: Cheshire Posts: 19 ![]() ![]() ![]() |
Yes and I can even switch between the two whilst the fault is occurring and that doesn't make any difference
The doc Member Since: 25 Mar 2007 Location: In car hell :-( Posts: 425 ![]() ![]() |
jayzee Member Since: 14 Oct 2009 Location: UK Posts: 342 ![]() ![]() |
Try turning off your aircon and see what happens. |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3781 ![]() ![]() |
might be totally off the mark here, but if you have had a new radiator fitted, could it be an airlock preventing circulation of coolant, the thermastat then gets hot and then the fan cuts in as its over temp? |
You say it "Switches off"
Doc - I did think this might be the first thing to try but when the dealer said Thermostat I put my trust in their opinion. What parts would I need to replace, any idea how much I would be looking at?
If the Viscous fan locked, and the electric fans are on then I would say that regardless of what the temperature gauge is reading the engine is overheating. One relies on mechanical means to engage and the other relies on an electrical sensor. (I believe the electrical cooling fan uses a different temp sensor to the dash gauge)
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
You can check the viscous coupling easily. With the car cold you should be able to spin the fan by hand.
Dan - this sounds worrying. The heater doesn't get particulalry hot.
Ian - it spins freely by hand with the engine off. |
I think the radiator being hot at the top and cold at the bottom may be the key to this, I wonder if it could be a problem with the water pump? |
