Home > Technical (L322) > bonnet lettering
daveo
bonnet lettering
hi has any one got the right measurements for the front range rover badge, it has come up on the template but how high are the letters ment to be from the bottom edge of the bonnet and whats the distance between the range and rover part, the dealers said line up the template with the bottom edge but then the letters look way to low.
thanks V8 facelift Range Rover Autobiography 22" wheels.
Post #123089 22nd May 2012 7:23pm
32mm from the bottom edge to the bottom of the letter
92mm between RANGE & ROVER
Post #123091 22nd May 2012 7:27pm
Thats interesting mine are 38mm and 90mm.
Post #123095 22nd May 2012 7:30pm
Depends what day of the week they were fitted Laughing
Post #123097 22nd May 2012 7:33pm
daveo
hi thanks for that Thumbs Up , where did you get that info from, is it in rave V8 facelift Range Rover Autobiography 22" wheels.
Post #123102 22nd May 2012 7:42pm
Got mine from measuring the front of the bonnet Thumbs Up
Post #123106 22nd May 2012 7:50pm
So did I. Thumbs Up Nothing on the tv tonight. Very Happy
Post #123115 22nd May 2012 8:02pm
daveo
thanks for the replies V8 facelift Range Rover Autobiography 22" wheels.
Post #123120 22nd May 2012 8:43pm
Mr Tee
Need the measurements for the rear lettering, what is the distance from the top of the trim strip to the botom of the letter? Thanks.
Post #123299 23rd May 2012 7:22pm
daveo
well i was at the dealers to check, the front was as stated around 30/32mm from the bottom of the letter to the edge of the bonnet and around 90 to 94mm between the two.
on the back it was around 40/42mm from the bottom of the letter to the edge of the upper tail gate and again around 90mm between the two words.
i think they are hand fitted and can vary slightly V8 facelift Range Rover Autobiography 22" wheels.
Post #123303 23rd May 2012 7:31pm
