Home > Maintenance & Mods (L322) > DRL's in foglights
DRL's in foglights
I been looking at fitting drl's to the car but decided against all the after-market lights available due to the "stuck on afterwoods" look of them.
Had a look on Disco 3 and found this which I think has been highlighted before on here.
I quite liked the idea of the led rings inside the fog light housing and as a result took a fog light off the car and found the fog lamp assembly is exactly the same fitment as used in the D3 and for that matter the RRS.
Bought some led rings, fitted them as per the D3 forum guidance, wired them and below is the result.
The pictures don't do the leds full justice in daylight as they are very bright in reality and perfectly acceptable as drl's.
In the dark they are far too bright so I have wired them to come on with ignition on and so that they dim on selecting dipped beam headlights. The alternative would have been to wire them so they turned off on selecting dipped beam.
Having fitted them this way their operation doesn't affect the fog light operation at all, they work independently as originally.
I quite like the understated look of them, to the untrained eye they could be original fitment.
Carrying out the fitting is relatively simple, if a bit fiddley, and takes about 4 hours (if you're quick Very Happy ).
Also has the advantage that the lights could be removed without trace if you decided to sell the car as original.
Post #122834 21st May 2012 10:06am
Thumbs Up I rather like them! Got - 2017 SDV8 Autobiography in Loire Blue
Post #122840 21st May 2012 10:32am
mjdronfield
Whilst I am sort of "Mr Original Man", I don't dislike them.............
I think Joe90 was looking at having his front fogs as DRL's - this could be an option if that doesn't pan out...
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #122845 21st May 2012 10:43am
That's a good way to do it, looks good!
Can you put up links to the kit you used?
Here is my approach (as with Stan too)
http://www.fullfatrr.com/gallery/thumbnails.php?album=466 .
Post #122857 21st May 2012 11:58am
These are the led rings I used but they are available from a number of sellers in
China / Hong Kong
Led rings
This is the relay I used to switch them.
You could use a standard change over relay and resistor but I thought it was easier and tidier just to buy the kit ready made.
Relay
Post #122863 21st May 2012 12:22pm
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
Prefer them to the pointless stylised bling 'sidelights' on my 2012 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #122864 21st May 2012 12:22pm
@ nicedayforit
Yep, I used the same relay unit. Might add the Angel Rings to my setup Smile .
Post #122865 21st May 2012 12:28pm
daveo
they are on the inside of the spot light... are they.what size ring did you use V8 facelift Range Rover Autobiography 22" wheels.
Post #122900 21st May 2012 4:13pm
Nice... Think I'll do this. Cheers for the info. Thumbs Up Previously..
Post #122904 21st May 2012 4:23pm
@daveo
The rings are 80mm external diameter and are mounted inside the foglight assembly just behind the front glass.
The foglight assembly comes apart really easily as below.
I stuck the rings in place with dabs of clear silicon, on D3 they seem to prefer use of a hot glue gun.
Post #122906 21st May 2012 4:29pm
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
Thanks for that. Just what I've been looking for. Very Happy Very Happy Silly question but does it give any fault codes ..
Gary
Post #122910 21st May 2012 4:59pm
The wiring and switching for the led rings is totally separate from the wiring for the foglights themselves and so doesn't affect the i bus system at all. The led circuit isn't monitored. If you get a fault on the led circuit no fault codes show.
The only connections to the vehicle wiring are the connections for the ignition supply to switch the leds on, I took this from the red/green cable at the headlight plug on the LH side of the car and also a connection onto the larger yellow/green cable to serve the coil on the relay and so dim/turn off the leds off, at the same position.
Both connections were made by splicing into the cables and soldering the additional cables.
Post #122916 21st May 2012 5:15pm
Heyloft
2019 Range Rover Vogue SE SDV8 Carpathian Grey
I quite like the look of these for my 2012 but.....
Is there any way to get a higher light output from the existing LE's in the headlights or replacing them with other LEDs as the existing ones are pants.
I haven't taken the headlights out of mine yet to take a look but is it possible to get to the led components without taking the headlamp unit apart and fixing it back together? Wot's that in old money
Post #122966 21st May 2012 10:04pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Looking at doing this mod but dont think the LED's bright enough compared to what you see on current models. The LED's need to be high output or have a lens to improve output like I think Davo was looking at in his headlamps, Any idea where to get such things? Mine was a blue one! Smile
Post #122998 22nd May 2012 8:16am
my 18 smd's in my fogs are bright enough, you dont wont to be to bright like some cars are... ... - .- -.
Post #123000 22nd May 2012 8:18am
