Home > Technical (L322) > upper tail gate removal |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
There is a tailgate up on fleabay at the moment without the glass fitted and it looks like the wiring harness goes from top to bottom on the righthand side and then the glass is bonded in after - so I suspect the wiring must all plug in inside the headlining. I maybe wrong - but have a look at the description/photo :- Item number: eBay Item No. 300704501633 |
18th May 2012 5:18pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Don't drop it!!! Craig |
18th May 2012 5:42pm |
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 208 |
yes had a look at the one on ebay and it confirms what i said the wiring must have been installed prior to the glass fitment . had a look at the harness in an l322 at my local breakers with the head lining removed and there is no multi plug the wires go into the main loom.
18th May 2012 7:16pm |
