Home > Maintenance & Mods (L322) > Are injectors a DIY job ?
Johnte
I'm pretty sure I need at least one injector. Symptoms are - slight missfire, smell of diesel, juddering when slow speed maneuvering.
I had this about a month ago, put some injector cleaner in and it cured it, but now it's back Big Cry
I'm assuming I will be able to determine which injector it is with a leak off test. Is it just a matter of unbolting the old one, and bolting the new one in ? Whistle
Anyone know a source of reasonably priced injectors?
Is it possible the injector could also cause the 'tappety' noise I've been getting?
Thanks Thumbs Up
Post #121014 9th May 2012 2:05pm
Depends, if they come out easy then yes, but they can get seized in on the bmw diesel engine and they then require some pretty serious work to get out.http://www.youtube.com/watch?v=nK8MqxEeMJY There is nothing that can't be fixed with a hammer😜😜
Post #121030 9th May 2012 4:28pm
Johnte
Shocked Shocked
Post #121036 9th May 2012 5:29pm
Johnte
Got them all out today, not too bad a job Whistle 5 came straight out, but the last one took about an hour (why is there always one Big Cry )
Off to the re conditioners tomorrow for testing !!
Post #121221 10th May 2012 8:07pm
Olders
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Johnte.
I think I have just the same problem.
What faults showed up when you read the fault codes?
How much are you looking at to recondition?
Cheers! Thumbs Up -----------------------------------------------
2016MY FFRR 4.4 SDV8 Autobiography Loire Blue
2007MY FFRR 3.6 TDV8 Vogue SE Tonga Green
Post #121635 13th May 2012 7:13pm
Johnte
I can't remember exactly how it was worded, but something similar to "Engine stability control"
They're away at the moment getting tested at £15 and if they need to be reconditioned I've been quoted £95.
Hope this helps Thumbs Up
Post #121636 13th May 2012 7:24pm
