![]() | Home > Maintenance & Mods (L322) > Pre 2010 headlight upgrade? |
Hill Billy Member Since: 31 Dec 2011 Location: Derbyshire Posts: 10 ![]() ![]() |
Just seen these on ebay item eBay Item No. 150813925593
Interesting, look forward to seeing yours! Do you heat them in the oven to split them?
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
i would love to see these angel eyes with the standard back colour, and the standard bulbs in day light and at night as well, dipped beam and just side light would be great
jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563 ![]() ![]() ![]() |
Good work Hill Billy! I saw this item months ago, forgot to add it to my watch list and couldn't find it again - I've been looking for it ever since!
i am using the 120 smd rings but they have the plastic diffuser over them like the 2012so you wont see the yellow smd through the clear plastic, it looks ugly when you can see them.the rings i have ordered are 6000k and will be visible in bright daylight, i think i will wire them to my side lights so i can have them on when i want..
hold on before you going spending big bucks, splitting the lights is not that hard, i dont use an oven just a heat gun, i have done a step by step guide on how to get them apart, it will go on to show how to fit the halos V8 facelift Range Rover Autobiography 22" wheels.
where did u get the rings from dave, and how much?
Could you post a link to the headlight splitting procedure.
dannyp15 Member Since: 21 Sep 2011 Location: essex Posts: 244 ![]() ![]() ![]() |
looks good Dave
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Hi Dave
ok, i have done a deal with the suppliers to get this set at half price, they run at around £70 for the full kit including loom and relay. now as i have not tried these so i dont know if they are any good, but i will let you know, they are meant to be around 6000k i dont want to go any higher then that as they look to blue, yes they do rings small enough for the fogs, you can if you want put yellow led's behind the reflector as craig has done,
