![]() | Home > Maintenance & Mods (L322) > Got new style flip key to work..! |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 ![]() ![]() ![]() |
Hi Daveo, and everyone else,
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3870 ![]() ![]() ![]() |
When I have struggled with glueing I have used two part epoxy never yet failed. Geoff |
hi all, with reference to robbo's last post i will hang five on ordering the spare key blanks,he is away for a week but if you fill you still want one regardless then let me know.
Hi Dave,
Programming a new Key
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Do these new keys req the old transponder to be put inside? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
Yes it's on first page..
How do you get the blade out? I've tried pushing the split pin but to no availe. Do I need to use more force? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
No force is needed. The blade pops out with the silver button thing still attached. Just make sure u dont lose the little spring inside. When ur putting the blade back in u need to wind it on the spring, so when u press the button it springs open. Hope that makes sense.
i think he is talking about the blade, yes there is a pin in side, one hole i slightly larger the the other so that's the hole it comes out of, you can use a nail or any thing pointed as when it goes in it will force the pin open and hold tighter, i use a link extractor as its a harden pin with a flat end fit in the hole 100%, now you need to get it firmly seated and flat, NO vice or pliers as you will end up marking the chrome blade holder, if you rest it on a bit of soft wood and start it of you will see it coming out of the bottom, once you have it started you can line it up over a hole and knock it out, do not grip it with pliers as you will crush it and it will never go back. V8 facelift Range Rover Autobiography 22" wheels.
Ok lads, seriously, it seems yous are making this harder than it is. |
Only copping on that the new fat blade won't have chrome holder on it, hence why ur trying to get skinny one out..!
email from the supplier received today, they have informed me they are senting out the correct blades, as your aware in US at the moment so well have to wait and see when I get home what they send.
hi all, to all those that had the flip key from robbo, could you check to see if you have both chrome corner to the remote, one holds the key and the other is if you want to fix to a key chain, as my one has only the one.... V8 facelift Range Rover Autobiography 22" wheels.
