Home > Maintenance & Mods (L322) > Dead VentureCam fixed
CBH25
Australia 2003 Range Rover Vogue 4.4 V8 Santorini Black
Just posted this on Aus L322 site, and thought it might be relevant here.
I've searched without finding an existing thread to tag into.
My MY05 Vogue came with a dead venturecam, no lights, not working.
I cracked it open and found the rechargeable batteries were kaput.
I was able to source some new batteries and solder them up in the same sequence, bingo, Venturecam - working and charging.
Just wanting to encourage others to do the same if they're interested in getting theirs working. Better than buying a new one from LR for A$750..... L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not Smile
L322 4.4 Vogue MY05 - Sold to my brother
P38 4.6 HSE MY97 - Regretfully sold
Post #120697 7th May 2012 12:36pm
good to know, thanks... Thumbs Up ... - .- -.
Post #120734 7th May 2012 4:37pm
stu
silly question maybe, but how did you go about opening it up?? i have looked at this but didn't want to damage anything.
any help advice pics etc appreciated. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #120741 7th May 2012 5:46pm
CBH25
Yeah theres a melted rubber seal around the perimetre which you have to slice/crack, and I butchered mine up a bit.
After that theres a clip at the centre back and then at 10am and 2pm - so three in total.
Gently Gently prising open the clips as theres wiring in there close to the edge that you dont want to slice them..... L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not Smile
Post #120789 8th May 2012 1:15am
stu
thanks for that, have done it!! all opened up and have opened the battery pack up too. i will get batteries when i get a chance and see how it goes.
thanks again.. Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #120792 8th May 2012 4:42am
daveo
there is a post about this somewhere, it started with the same problem,cam not charging. i came across this quite awhile ago when a friend bought a 2006 and the cam was dead, i managed to jump start the battery with out opening it, some times the battery's get so low that one of them can change its polarity. i repaired his this way and they it went on working even after he sold the car, the same with my two and i have not had any probs, i all so repaired a pair for a member on this forum, V8 facelift Range Rover Autobiography 22" wheels.
Post #120795 8th May 2012 6:44am
And it's still working dave... Thumbs Up Previously..
Post #120800 8th May 2012 7:14am
stu
well i've just had a go at repairing a dead cam. i opened it up and removed the battery pack. went to tesco and bought some AAA rechargable batteries. the cam uses six of said batteries, they are maybe not quite the same but you got to try these things.
i then de-soldered all the wires from the battery pack, mirrored the way they were linked by soldering some copper wire accross the terminals as required to link the six batteries and put it back together. forgot to say i used sellotape to hold all the batteries together in a pack, didn't have any heat shrink wide enough.
hey presto she has fired up... Laughing
haven't actually paired it with the car yet as i have sealed around the case with RTV gasket stuff in a sexy shade of black.. Razz when that has dried off a bit i will give it a try out in the cradle and see if it pairs ok with the car.
if it works deffo a cheap fix.. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #121595 13th May 2012 12:47pm
