Home > General > Strange water noise from rear drivers side door when raining |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 |
Sometimes I find water trapped between the door seals after it has been raining on the drivers side (rh) rear door.
8th May 2012 7:10am |
HAve you checked the boot area for water ingress? |
8th May 2012 8:47am |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 |
I also find water trapped between the door seals after it has been raining on the drivers side (rh) rear door! |
8th May 2012 11:05am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3964 |
Could be just water running down the drainage channels either side of the tailgate door. I've noticed mine make a bit of a noise in heavy rain, it surprising how much water can run down them.
8th May 2012 11:09am |
JIMMYM Member Since: 06 May 2010 Location: Saddleworth Posts: 29 |
Had the same problem on my Td6 on both back doors holding water between seals and getting a deluge when opening back doors after rain. If you look at bottom of doors there's a drain hole outside the seal. Apparently there's a water shedder plate inside the door that is supposed to channel any water coming into the door via the window aperture. These shedder plates often come adrift - the cure is to strip the interior door panel off and refix the shedder plate with a sealant like Sikaflex. You'll find that if you look at the bottom of your interior door panel after rain it'll be wet. This confirms that shedder not doing its job and letting water past which is then trapped between the double seal on door. Never got around to fixing mine tho. Common problem according to my clued up Indy. |
11th May 2012 10:38am |
