Home > Maintenance & Mods (L322) > Went to JE Engineering and had Td6 Remap..........
fisha
I think on single trips with a reset at the start, then higher figures are possible.
For example, reset as I leave work, and a gentle run home could see me back at the door with the 24 mpg on the dash ( BMW 4.4 )
However, after a week, its back down to 17. Laughing
So single trip runs can be misleading imho. V8 or else ...
Post #120452 5th May 2012 7:10pm
indeed...resetting the 'puter and you will only get the mpg figures for that journey not a proper average... ... - .- -.
Post #120457 5th May 2012 7:25pm
According ti the Computer in my tdv8 i get 20.1 long term average, that includes a bit of motorway, a fair bit of towing, and a lot of town driving.
If i reset the second trip then i can get the journey average. Usually about 20 no matter what i do.
Just cost me over £140 to fill it Whistle
Did treat it to super derv though. There is nothing that can't be fixed with a hammer😜😜
Post #120573 6th May 2012 5:33pm
Jcsh
France
Re: Went to JE Engineering and had Td6 Remap..........
mjdronfield wrote:
......yesterday........
Well happy. The car feels like its got a bigger engine, is more smoother, and I'd swear it's more quiet now cold, than it was previously when warmed up.
The mid range torque is immense. So much nicer to drive.
<snip>
Yes there is more torque about, going through the old GM box, but I figure if I can get the same performance as I did before, without having to rev it as high, its got to be better all round.
Mark
Mark
I'd be saving up for a new box if I were you, as you say the box is maxed out at the engine's std torque setting and now you've upped it massively. Revving it high is not the issue - the torque is produced when you bang the throttle down at a low rev range.
sorry to be negative as I totally appreciate what you mean about the car needing the extra oomph but BMW screwed up big time by speccing this gearbox and using a blind eye won't obviate physics I'm afraid Sad
Post #120626 7th May 2012 12:44am
stu
BMW had trouble with their own cars the X5 i am on about, the torque convertors used to let go at fairly early miles.
only fix is a £2k upgrade for a heavy duty item, of course they denied their was ever a problem!! Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #120639 7th May 2012 7:20am
mjdronfield
Well. I know what you are saying.........I understood the issue with the gearboxes was not torque related, but the valves etc wearing out their outer casing as it was made from "softer" casting than usual.
When I was on about less reving, I was talking about the engine wear........not box.
If it's gonna blow, it's gonna blow !!
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #120708 7th May 2012 2:18pm
On a run i can easily see over 25-26mpg and the last run from huddersfield to manc saw me at just over 31mpg there and back with a full set of wheels and passanger on board and full load of fuel.
TBH the car does WORSE on normal diesel compared to BIO and i can feel the power drop Sad
avg about town with an avg speed of circa 30mph according to the computer gives me between 19-21 Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #120731 7th May 2012 4:24pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
I average normally about 25mpg overall. I have managed over 30mpg on 300 mile round trip on main roads. My computer is pretty accurate as I have done tank to tank fills and compared the results a couple of times. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #120744 7th May 2012 6:06pm
