Home > Off Topic > ipod touch - Problem |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 |
connect it back to iTunes and do a full restore - should sort out any software problems |
3rd May 2012 7:59am |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
Go into settings and disable iTunes Match - it's trying to store the songs on the PC and in the cloud and pull them from there instead of storing them on the device - it will also try to update the play count for each tune and app that is used. |
3rd May 2012 11:14am |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
I had this.
3rd May 2012 11:50am |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 738 |
Graham - Her old password is working no problem, but it's just that it's always asking for it to be entered (every 2 - 3 minutes) Was that the same with you?
3rd May 2012 1:14pm |
Johnte, let it run a back-up, then everything is saved (progress in games/emails/messages etc), then do the factory restore. This reinstalls the main software and settings, then you can 'restore' from the backup you have just made. iTunes will prompt you if you want to restore from a backup or if you want to set it up as a new iPod. |
3rd May 2012 2:00pm |
Or you could do what I suggest, as it's the answer to the problem...
3rd May 2012 2:48pm |
