Home > Technical (L322) > My L322 v8 won't start! |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
firstly are you sure you have a good voltage coming of the batt, put your lights on and use your windows up/down. if they appear fine the next step would be think..when you last used it was all ok... do you here the click as you put your key in, if yes i would check the wires on the starter to make sure they are tight. V8 facelift Range Rover Autobiography 22" wheels.
29th Apr 2012 2:28pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
just an idea, there are inhibitor switches on the gear selectors to stop you starting the car whilst a gear is selected. my D2 has this problem and it wouldn't start sometimes, due to a dodgy switch. all i used to do, was pull the gear selector fully up and down through the range a couple of times and turn the key and up the old girl would fire. love that V8 burble..
29th Apr 2012 2:30pm |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
Is the gear switch a bit sticky? Does the car think it is in gear and therefore not starting. It's unlikely but just a thought. No longer FF owner but still interested. Present car Jaguar XE
29th Apr 2012 2:31pm |
great minds think alike... Current: TDV8 (3.6) RRS HSE
29th Apr 2012 2:36pm |
SSSL322 Member Since: 09 Apr 2012 Location: Surrey Posts: 15 |
Thanks for all the replies it's actually started now and fine so I'm baffled!!! ...it's done it aces times and my mechanic told me to wait until it properly broke!!!
29th Apr 2012 6:58pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
Could be the transponder in the key.
29th Apr 2012 7:37pm |
