Home > Technical (L322) > Whats Best ??
hoppy
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Whats Best ??
http://www.lrparts.net/pp/RANGE_ROVER_L322...2-2005.htm
versus
http://www.rswsolutions.com/index.php?opti...;Itemid=81
the reason i ask is, main dealers gonna charge me a lot more to fix my keyfob problem, would either of these
allow me to fix it myself??
Post #119446 28th Apr 2012 1:46pm
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
I have the RAC ALL COMMS and I havnt come across anything on it for the key fob.
Someone else might be able to help if you post what the problem is Thumbs Up
Post #119450 28th Apr 2012 2:00pm
hoppy
from what i've read it seems the car.s in "transport Mode"...
would think one of these would be able to sort that
Post #119452 28th Apr 2012 2:06pm
Bob the B
With the rsw one I have seen something on the suspension settings to put it in to transport mode.
I dont know if this would sort your problem out.
How this relates to a fix for your key fob I dont know Confused
Post #119457 28th Apr 2012 2:14pm
hoppy
if it can be taken out of transport mode i can sync the key...i believe
Post #119461 28th Apr 2012 2:34pm
Black_64
Belgium
I have the IIDTool and it can put your car in Transport Mode (Build Mode).
To get it out of Transport Mode there is a Re-Enable EAS option.
I don't know if this will fix your key problem.
Quote:
Build / Transport Mode
This deactivates or re-activates the air suspension.
When an EAS equipped vehicle is transported on a trailer, entering build/transport
modes keeps the EAS from lowering. This prevents a loosening of the tie down straps.
Note: Activating the Build Mode / Transport may cause an error to appear on the instrument
cluster. The EAS ECU is deactivated and this may affect other vehicle systems.
Upon exiting the Build/Transport mode, the error will disappear.
The IIDTool developers listen to the needs of users and add options (if possible).
Another nice feature is changing the CCF. (Car Configuration File).
You can take a look here for the Functionality list (select car and year): http://gap-diagnostic.com/products/iidtool.html
I found this tool very easy in use. No Cables and small enough to have it always with you (or in the car).
Post #119500 28th Apr 2012 6:56pm
Reformed
Somebody on here is selling one;
http://www.fullfatrr.com/forum/topic11141.html Reformed
Post #119502 28th Apr 2012 6:59pm
hoppy
thats just eas tool tho....
Post #119505 28th Apr 2012 7:53pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
CCF modification is coming...it's not out yet. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #119510 28th Apr 2012 9:22pm
Black_64
Belgium
Correct, but that everybody's knows after this video: Preview to coming IIDTool update...
Post #119520 29th Apr 2012 7:13am
