Home > In Car Electronics (L322) > Rotary volume control playing up :-(
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Hi Guys,
The rotary volume knob on my touchscreen unit has started playing up. When I turn the volume down it sometimes increases before it reduces and vice versa.
It's not covered by the LR Select warranty and I imagine a replacement unit will be very expensive. Has anyone else had this problem, and do you know if the rotary encoder is optical, if it's not then it may just need a clean.
Thanks,
Justin
Gone - Range Rover Supercharged 2006
Post #118350 19th Apr 2012 7:52pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
Mine does that too, sometimes the volume won't adjust at all on either the steering wheel or the touchscreen.. I just put it down to electrical gremlins.. I turn off the screen and back on and all good again.. Thumbs Up
Post #118363 19th Apr 2012 8:37pm
JustinP
My steering wheel controls are 100% reliable, so your problem looks to be different from
mine. As a precaution, check your boot for dampness.
Post #118365 19th Apr 2012 8:41pm
daveo
its not optical, i have one in bits, its resister based and there is not much visible but i would go for a few squirts of contact cleaner,you have nothing lose.
but you will have to completely dismantle to get to the switches, i would not take the chance spraying it from the front.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #118370 19th Apr 2012 8:59pm
JustinP
Thanks mate Thumbs Up
Post #118373 19th Apr 2012 9:06pm
simon1233
I just had mine replaced under the LR approved warranty last week, apparently the replacement unit cost £1516.56 Shocked
Glad the warranty company picked that one up...
I had the same symptoms as you describe with the rotary switch doing what it feels like but eventually working. My steering wheel controls were always OK.
Would try switch cleaner first if you don't have warranty cover Thumbs Up
Post #118374 19th Apr 2012 9:08pm
could be dust justin, try a few sharp taps with a screwdriver handle on the knob.....worked for me on a house stereo... ... - .- -.
Post #118394 20th Apr 2012 7:34am
is it not possible to just buy a replacement board? There is nothing that can't be fixed with a hammer😜😜
Post #118509 20th Apr 2012 8:00pm
daveo
certainly not from land rover with out a doubt, i know the non touch screens were made by alpine but not sure who makes the touch screen. V8 facelift Range Rover Autobiography 22" wheels.
Post #118513 20th Apr 2012 8:32pm
JustinP
I think denso made them.
Post #118521 20th Apr 2012 9:08pm
pretty sure its denso.
Round here we have a place called mobile solutions, they seem to have the ability to repair quite a lot, maybe there is somewhere similar near you who can perform a fix.
Or maybe an electronics services http://electronicservices-derby.co.uk/electronic-services ? There is nothing that can't be fixed with a hammer😜😜
Post #118925 24th Apr 2012 7:41pm
