Home > My Range Rover > My FF RRVSE |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Hi all
11th Apr 2012 10:24pm |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
Ooooh, a Lotus Carlton. I had one once. Nice. Bit scary, in a sort of 1980's uncontrolled kind of way. Graham
11th Apr 2012 11:09pm |
It looks small. I remember it as a great big scary 380BHP thing. Graham
11th Apr 2012 11:10pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35439 |
looks very nice andy... ... - .- -.
12th Apr 2012 7:48am |
The LC is a big beast and is very scary in the wet. The FFRR is massive and makes anything look small.
12th Apr 2012 9:14pm |
5IMON Member Since: 27 Nov 2011 Location: London Posts: 165 |
Wow a lotus carlton they are rareee |
12th Apr 2012 9:23pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
Hi Andy_J , SNAP!!! I'm A FFRR and Lotus Carlton owner myself , think we could form an elite sub-FFRR club !! The LC makes the RR the cheaper car to run! Steve
19th Apr 2012 4:08pm |
This is mine by the way...
19th Apr 2012 4:14pm |
Steve, looks like your LC is in better condition than mine, but I would expect that if you have had yours 16 years. The one think i like about having an LC up here is the nearest speed camera is 60 miles south of me 56 TDV8 Vogue SE
19th Apr 2012 9:47pm |
Hi Andy, Mines currently in a specialist garage having a misfire investigated. If ever you need to source parts for it let me know as they're rare and I spent so much time and money on it over the years I usually have a good idea where to get them as I've built up quite a base of contacts . e.g. original coil pack and interface was £1580 new (it was the 1st thing I had to get for it , luckily under a 3rd party warranty) , I've now got this down to as low as £100 for 3 coils & interface by importing from the USA!!! Steve
19th Apr 2012 11:39pm |
Thanks Steve the biggest issue I have had in 2 years in the 3 way valve, took me 8 months to find the coolant leak. The only rare bits I am after are the adaptors for the aircon as mine is still set up for r12 (but is empty). Are you a member of Autobahnstormers? I am quite familiar with Lotus and their GM sourced parts as I also have an Elan M100 and the only car the the engine is comon to is the Isuzu RS Impulse (which was only sold in the US) 56 TDV8 Vogue SE
20th Apr 2012 12:20pm |
Hi Andy, I've not had the coolant leak issue (which surprises me as I've had everything else!!). I went to an air-con specialist about 1.5miles from my house to see about converting my A/C to modern day coolant etc and 2 days before I was going to take it in, I had a major engine issue so haven't been back yet. He was going to pressure test my system first, and if OK, he had the relevant connector adapters to convert it and was going to use a bottle of fluid that apparently reacts with the freon to neutralise it, and then you can use a modern regrigerant without removing the old. The charge was going to be @£125 . The adapters seemed to be straightforward to do, he had a box full of them as I remember as he was showing me them. The 2 aircon connectors are quite a way apart so I had printed off the diagrams to show him where they were. I'll get back there one day!! Steve
23rd Apr 2012 5:06pm |
