Home > eBay & Bargain Spots > 2010 Reverse Camera up for grabs..
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
http://www.ebay.co.uk/itm/RANGE-ROVER-REVE...0784979549
Post #117981 17th Apr 2012 3:02pm
looks like it would fit earlier models but the connectors may need modifying.
Post #117982 17th Apr 2012 3:11pm
daveo
the 2010 and on have different connectors they use a 4 pin power connector as where the older ones use just a 2 pin. be careful you could make an expensive mistake V8 facelift Range Rover Autobiography 22" wheels.
Post #117989 17th Apr 2012 4:27pm
Lolo
Daveo, could u solder the wires together..?
Post #117990 17th Apr 2012 4:34pm
daveo
hi this is a typical pre 2010 camera 2 pins 12v and ground along with mini video plug, this is not a prob and you find as this one is from a 2007,its a ccd camera
the 2010 cameras have 4 pins and are HD, now you wont benefit from HD as your screen is still quite low res
the range rover cameras are not the best quality and with out a dooubt the early 04 up to 06/07 are Censored
they are cmos and pron to letting in water so dont buy one of them, at the same time the res was not a prob as the pre touch screen res was no better then the camera, the res on the touch screen nearly doubled and then they used the ccd camera giving a far better pic.
now on the new2010 screens they are hi res and give a great picture and are capable of zooming in with a camera and still giving a good pixel free picture and before any has the idea i dont think the 2010 screen will work with earlier touch screen cars as for a start the can bus is twice the speed on the new cars and not compatible.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #117994 17th Apr 2012 4:54pm
interesting info dave.. Thumbs Up ... - .- -.
Post #117996 17th Apr 2012 4:57pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
I've got a 2010 camera and it's the same connections as the 2007 i.e. you buy the look and it outputs 2 pin power and SMB Coaxial.
N.B. the 4 pin is to go with the surround camera option.
HTH. Still meaning to do a write up but work is so Censored lately that i haven't got any time= sorry.
Post #118018 17th Apr 2012 6:55pm
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
Big Thanks Daveo. Stopped me making an error Thumbs Up Was looking at it for my MY05
Gary
Post #118302 19th Apr 2012 2:34pm
