Home > Maintenance & Mods (L322) > How to get items out of windscreen demister vents?!
CBH25
Australia 2003 Range Rover Vogue 4.4 V8 Santorini Black
Hey FFRR team.
Newbie to LR's and loving my '05 Vogue.
Dropped a bolt down the demister hole below windscreen today, wondering if theres a trick to extracating it?
Tried looking under the pollen filter, no luck...
Any one else found a solution to this?
Thanks
CBH25
Post #117663 15th Apr 2012 10:15am
hi mate and welcome to the forum..
i would think the best way would be to take the top dash off and get it that way... ... - .- -.
Post #117664 15th Apr 2012 10:17am
CBH25
Thanks!
Thats exactly what I was doing when dropped it down....
Even with it off, there is no access or visibility down the demister vents, the dash ends before the vents.
Any other thoughts please?
Post #117666 15th Apr 2012 11:10am
Small magnet on a piece of string? Very Happy
Post #117667 15th Apr 2012 11:23am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Magnet should work.
I dropped a fixing inside the engine bay, it fell onto the under engine cover, fished it out with a magnet, found it and dragged it off to the nearest hole.
Post #117668 15th Apr 2012 11:29am
CBH25
Magnet is a brilliant idea, thanks.
The hole is very small so it wont be very powerful, but i'll give it a go.
Still, if anyone knows an easy way to get into the demist vents, please let us know.
Post #117671 15th Apr 2012 12:46pm
This is the air duct system. Item 2 are the windscreen air vents.
To be honest unless you totally dismantled the dash I doubt you you could get in to remove the offending duct to get to the screw. You could always hope it's settled somewhere never to be seen or heard of again. Very Happy
Post #117672 15th Apr 2012 1:03pm
CBH25
No luck with the magnet, wont drop down far enough.
Luckily, it has dropped somewhere silently Thumbs Up
Thanks for the suggestions. If you're working on your dash, keep a grip on those bolts, they roll straight down the dash into the hole! L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not Smile
L322 4.4 Vogue MY05 - Sold to my brother
P38 4.6 HSE MY97 - Regretfully sold
Post #119541 29th Apr 2012 10:55am
