Home > Technical (L322) > SUNROOF PROBLEM |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 |
I need to check my Rave Manual, but is there still a manual key under the switch panel, maybe correcting it manually will reset it.
26th Jan 2010 5:56pm |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2042 |
Do they have a anti trap sensor? |
26th Jan 2010 6:06pm |
Why not try this?
26th Jan 2010 6:17pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
do you mean when you try to open it goes back then comes back forward to close and so on , if so i had this problem and you cannot just reset by holding tilt as it will not work what has happened is as its opening its hitting a soft limit at full open then closing
26th Jan 2010 6:41pm |
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 |
Thanks guys for your replies.Suppose first i try with easier proposal of manual setting.If nothing then i will try to see if i can manage it as per second suggestion of rruk.
27th Jan 2010 12:46pm |
