Home > Wheels & Tyres > What Tyre pressure for my Full Fat SC VSE
Goatboy1972
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Hi all,
My car is fitted with 22 inch overfinch alloys and Toyo proxes. Can someone tell me the correct pressures I should be running given the car normally has 2 adults and 3 kids in it (plus the associated junk that SWMBO leaves in the boot).
Many Thanks, Bruce
Post #117454 13th Apr 2012 12:20pm
Seen it on other forums , members usually put 38 / 40 in the rear and 34 / 36 in the front
Post #117458 13th Apr 2012 12:40pm
what mick says and also play with the pressures to see which gives you the most comfort..keep an eye on the tread wear , if it starts wearing in the middle then go down in pressure a bit and on the edges increase the pressure [thats if you havnt an alignment problem]
there isnt a standard pressure from landrover as they dont fit 22''... ... - .- -.
Post #117487 13th Apr 2012 2:50pm
