Home > Off Topic > Wheel refurb
Wheel refurb
Thought I would let you see what is possible on alloy wheels
The original wheels for the Audi A8 are diamond cut but the wheels on my car have been polished and lacquered. I needed a spare wheel for my car that would match the others and managed to find a slightly damaged wheel on ebay.
I removed the powder coating using 400 grade sandpaper on an air powered DA sander, then using 400 grade wet & dry I cleaned up the bare wheel face, then 1200 grade wet & dry to give a finer finish and eventually finishing with 2000 grade wet & dry.
Last night I started to polish up the wheel using Solvol Autosol and the results were encouraging although not as good as I needed, so today I spent another hour with the 2000 grade wet & dry to get a really smooth finish.
Click images for full size
This is the tiny marks that must be sanded out
The aim is to have a uniform even finish
Once prepared it took a maximum of 10 minutes to polish the wheel using the rotary and 10 minutes to finish by hand
The alloy used in wheel making is not completely smooth, so a complete mirror finish would be almost impossible, plus if it was a mirror finish the lacquer would not adhere to it properly, so I am happy with my efforts. Just need to get it to the paint shop now for the painter to do his bit.
Once the wheel is back from the paint shop I'll post up the pictures.
Post #117032 10th Apr 2012 2:43pm
wackyjim
Scotland 2011 Range Rover SE TDV8 Santorini Black
Post #117038 10th Apr 2012 3:01pm
You need a job , ya sad Censored …… Laughing Laughing
Wink Wink Wink want to do mine ... Laughing Laughing
Post #117043 10th Apr 2012 3:14pm
great job... Thumbs Up ... - .- -.
Post #117047 10th Apr 2012 3:20pm
I would love my FFRR alloys to be as shiny as that... Great job. It all comes down to having the time and making the effort I suppose! Previously..
Post #117052 10th Apr 2012 4:06pm
A job Mick, I have a disability and therefore unable to work. I suffer from heart and kidney trouble, heart lazy and kidney be bothered Thumbs Up
The hard work is in the preparation of the wheels, the actual polishing is the easy bit and takes minutes. The secret is to keep working dowwn from the 400 grade to 2000 grade paper. I might try and get hold of some 3000 grade wet & dry for the next time as it would give more depth and shine to the alloy
Post #117072 10th Apr 2012 6:12pm
did you rub by hand john or use a power tool.. Mr. Green ... - .- -.
Post #117074 10th Apr 2012 6:15pm
You're obviously feeling better Stan... Whistle
Post #117075 10th Apr 2012 6:17pm
Laughing yep..... Thumbs Up ... - .- -.
Post #117079 10th Apr 2012 6:25pm
Really impressive results! Thumbs Up Si. <This is my name.
Post #117083 10th Apr 2012 6:56pm
Shropshire lass
England 2002 Range Rover HSE Td6 Giverny Green
Great result! Thumbs Up
Post #117120 10th Apr 2012 10:17pm
