Home > Technical (L322) > Uncommanded Headlight flashing...
EDWARD757
2007 Range Rover Vogue SE TDV8 Java Black
Hi,
Wondered whether anyone had ever seen this? Headlights on or off, the main beam flashes sporadically without command. Cycling the fuse (third/fourth in on the left, top row) cleared the problem for a couple of journeys but it is back.
Any ideas?
Kind regards,
Ed
2007 RR TDV8 VSE '96 Volkswagen Polo 1.4CL - SOLD
'00 Audi A3 1.8T - SOLD
'97 Lotus Esprit V8 - SOLD
'03 BMW M3 - SOLD
'93 Range Rover 3.9 Vogue SE - SOLD
'92 Peugeot 205 GRD - DIED
'99 BMW 540i Touring - SOLD
'94 Peugeot 405 GDRT - SOLD
'00 Peugeot 406 HDI estate - 63mpg! - SOLD
'08 Range Rover TDV8 Vogue SE - SOLD
'11 Skoda Fabia Greenline II - 94.2mpg!- SOLD
'07 E61 BMW 530d msport touring - SOLD
‘20 Tesla Model 3 SR+
‘20 Tesla Model 3 Performance
Post #88974 26th Oct 2011 9:17am
dunwoa
United Kingdom 2004 Range Rover Vogue Td6 Adriatic Blue
Hi Ed,
Did you ever find a solution for this? I have the same problem on my rr my04. It started with uncommanded flashing, followed by a period where the main beam would not come on when commanded (either flashing or permanently on). Then after a few weeks it was fine again and then started all over. So clearly no problem with bulbs, must be a loose connection somewhere?
Regards,
Alan
Post #116914 9th Apr 2012 12:11pm
Indicator stalk? That would be my first checkpoint...
Craig Thumbs Up
Post #116917 9th Apr 2012 12:17pm
daveo
yes i would check the stalk and the relay as well, does it do it as your driving along or while you are sitting there.. V8 facelift Range Rover Autobiography 22" wheels.
Post #116957 9th Apr 2012 3:34pm
dunwoa
It happens as it's moving along only. I'll take a look at the stalk. Any idea where I find the relay?
Many thanks,
Al
Post #116959 9th Apr 2012 4:05pm
