Home > Technical (L322) > Problem with Air Con
sms720
Hi all
The front blower on my L322 (2003) has stopped working, no air at all coming out of front vents. The rear blower works fine and I have checked all the fuses are OK.
Is this likely to be a simple case of the fan blower unit just knackered?
Anyone else had this happen?
If so is this the unit I would need and is it easy to fit?
eBay - Heater Blower Unit
Thanks
Simon
Post #11644 25th Jan 2010 9:02pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Hi, not sure with a BMW It can be the final stage resistor pack may be worth a google? Common failure on A/C units.
Post #11651 25th Jan 2010 10:22pm
dan_uk_1984
+1 it will be your final stage blower resistor. It's an easy replace and can be done from the drivers footwell.
Post #11663 26th Jan 2010 9:34am
