Home > Technical (L322) > IIDTool Error Codes
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
IIDTool Error Codes
I know some members have gave their opinions on 1 or 2 of the following errors but just want to get the confirmed answer before I buy anything. Thumbs Up
Steve can you help with the following:-
8155 can instrument cluster node missing
30 air quality sensor line fault
38 open circuit activation sra, drm 2
Post #115988 2nd Apr 2012 12:18pm
SteveMFr
Site Sponsor
Here you are:
8155 can instrument cluster node missing: very common fault; lost communication errors are frequent and rarely need attention; these DTCs aid in diagnosing a real problem - does not seem to be your case (your dashboard would be lit like a Christmas tree).
30-air quality sensor line fault: check your cabin air filter; poss faulty sensor .
38 open circuit activation sra, drm 2: need more info: which ECU logged this error code?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #116138 3rd Apr 2012 7:24am
Lolo
Thanks for that..
38- BPM ecu
Post #116143 3rd Apr 2012 7:50am
Lolo
Steve, do u have any update on error code 38?
Thanks Thumbs Up
Post #116430 4th Apr 2012 7:28pm
SteveMFr
Site Sponsor
From Patrick and Christian:
Not easy to specify. It seem to be related to a CAN error like the lost communication errors. Does it come back after clearing?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #116526 5th Apr 2012 2:31pm
Lolo
Yes I have cleared It a few times, keeps coming back.. There's no panic on it, let me know when the lads have better idea, if they do.. Thanks Thumbs Up
Post #116556 5th Apr 2012 5:26pm
Lolo
Oh just to add, some from the forum have suggested it might be brake sensors..?
Post #116557 5th Apr 2012 5:27pm
stu
hi, hope you don't mind me jumping in here to ask a question.
does the IID tool have the ability to do things like turn on the automatic door locking when you drive off and the total closure of windows and sunroof, or are we still going to have to go to the dealers for these functions to be activated?
thanks in advance for any help. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #116741 7th Apr 2012 12:05pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Try using Search ....
However, if you had, you'd find it will soon. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #116743 7th Apr 2012 12:18pm
pcourtney
BPM Body Processor v10 0x38 Open Circuit Activation SRA, DRM
did GAP ever get back to anyone re: the fault below, I am not able to reset - but I don't think it is brake sensors, maybe Patrick or Steve could get back to us please
BPM Body Processor v10 0x38 Open Circuit Activation SRA, DRM 2
Post #558427 20th Jun 2020 11:11pm
