Home > Technical (L322) > Disconnect battery/reconnect battery
Glm
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Hi all, to try reset fuel gauge I have been told to disconnect battery and reconnect it? Not sure then what the procedure is? When I turn the steering wheel all the way to the left and then all the way to the right is that it ? Cheers Current tdv8 range vogue 07
Post #115551 30th Mar 2012 7:24am
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
The steering wheel left then right resets the steering and air suspension sensors. Make sure you follow the battery disconnect / reconnect procedure in the wiki as it has an explosive bolt on the positive cable that you do not want to trigger.
Its a simple process but with defined stages. "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #115552 30th Mar 2012 7:27am
Glm
Not sure but I have looked on the wiki to see if the procedures there but can't see it ? Current tdv8 range vogue 07
Post #115553 30th Mar 2012 7:30am
http://bimma.me.uk/2010/03/12/disconnectin...ation-rhd/ ====================================
Post #115555 30th Mar 2012 7:35am
Glm
Cheers for the info joker ! I am about to have a go ! Watch this space ? Current tdv8 range vogue 07
Post #115556 30th Mar 2012 7:39am
And if we don't hear back from you , we'll take it you blew yourself up …. Laughing Laughing Thumbs Up ====================================
Post #115557 30th Mar 2012 7:48am
^^^ Shocked Shocked Shocked
Cheery this morning Mick Laughing Laughing
Post #115562 30th Mar 2012 8:11am
As always John , as always … Laughing Laughing ====================================
Post #115563 30th Mar 2012 8:12am
