Home > For Sale & Wanted > Wanted air susp compressor
Andy
Anyone got a new or good used compressor? Dealer has just tested mine and it's not filling quickly causing the fault on the dash.
Apparently should be 11bar- mine is between 5-8bar.
Thanks on advance 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #115378 29th Mar 2012 11:21am
Sounds like the piston seal is worn out noddy Sad
i have one but its fitted to my ffrr Very Happy
there are some breakers on the bay that have a few kicking about i think so they should be able to help you Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #115383 29th Mar 2012 11:33am
No guarantees that a used compressor won't be any better than what you have Big Cry
Post #115400 29th Mar 2012 1:15pm
spanner
I had this problem stripped the compressor found the seal stuck in the groove of the piston I cleaned it cleaned the barrel then applied some vasalene that was 12 months ago no problems since and it only took 1 hour to do
Post #115453 29th Mar 2012 3:34pm
