![]() | Home > Maintenance & Mods (L322) > Intercooler leak |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
Changed the anciliary belts today an when under the car I noticed oil on the electric fan blade. I removed the grill and saw the oil leak was only on the bottom of the fan so deduced it to be an intercooler leak. Once I had the belts back on and engine running I can feel air coming out of the central top of the intercooler, it looks like some monkey fisted wrencher at the Franchise has damaged the I/C as it is crushed where the leak is.
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Not having seen a FF intercooler before, but very familiar with Defender intercoolers, I think you'd need to get that welded. Si. <This is my name.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Bond & Seal made by wurth works well |
Modern glues never cease to amaze me - but in cases such as this (heat cycles, pressure, etc) I still prefer to go with the 'real' thing. There is one on the bay right now
Well the story continues.
Sorry guys but I do not know how to link photos to here.
Best bet is to look up a copy of Rave.
Thanks for that, |
I am surprised there is no no. 8 wire involved in the fix you described or did you just not mention that |
Removing the IC is a bit of a PITA due to the AC condenser. If you are in a shop with access to an AC service station, you can evacuate the AC, drain the radiator, disconnect all hoses/lines/wires, unbolt the upper cowl cross plate, and remove the entire radiator assy. Of course you have to recharge the AC when done but I think it's still much quicker.
No sorry but I did use 0.8mm mig wire in my welder. And no I wasn't in Redband Gumboots and black singlet either ![]() Adrian VW Amarok 2014 Highline auto |
