Home > Maintenance & Mods (L322) > 4.2 S/C K&N Air Filter |
Best stick with the original filter, the K&N requires oiling and the oil goes onto the MAF sensor |
24th Mar 2012 11:49pm |
Best stick with the original filter, the K&N requires oiling and the oil goes onto the MAF sensor and boogers it up |
Don't notice any difference with mine in, for me it was the convenience of having a filter that I can clean when needed (especially after Harmatan). Not seen any MAF issues sofar due to the filter. MY 2010 5.0 SC Galway green and sand interior!!
25th Mar 2012 10:19am |
DiREW0LF Member Since: 11 Feb 2012 Location: Northern NJ Posts: 8 |
I would stay away from it just because of its filtering ability. It allows more air into the engine because its less dense than a regular filter. What makes it effective at all is the oil, but once it has a few miles on it the oil isn't going to capture the dirt and it will be in your engine. For a fair weather weekend car or racecar K&N's are great but for an off-roader or DD don't do it! Especially with the supercharger, a little dirt will destroy the seals and you'll end up way down on power. |
2nd Apr 2012 12:00am |
I have seen the raging war on the internet between pro and con of the paper vs. non paper filters. The main reason for me to switch to K&N was very simple, paper filters here are more expensive (than the K&N I bought in Europe) and flying them (paper filters) in every 10,000 to 15,000 kms seems a bit ridiculous. Whether they are better or not, I don't know based on the information that I have read sofar.
2nd Apr 2012 9:46am |
I agree that any filter is better than none. There isnt much to debate on which filters better and which flows better. Obviously to flow better a filter has to have larger passages with less restriction.
2nd Apr 2012 11:04am |
