Home > In Car Electronics (L322) > fuse 49
doug
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
fuse 49
hi, a few weeks ago my multi dvd player situated in the left of the boot,on my 07 tdv8 vse,stopped working,,it has no power going to it,and wont eject the dvd's
it didnt bother me much,but a week or so later,my battery died too
i replaced the battery for the equivelant,but a week later it has died too
when in the landrover specialist ,they said there was a drain which is flattening the battery,they said fuse 49 was using .68 something(ohms?) when it should be asleep,the car normally drains .03 naturally,they said fuse 49 is part of the entertainment system but were reluctant to start swapping things out and so referred me to my dealer,i'm not keen on this as the last problem took 3 days for them not to solve
my question is,,,,would it be ok to remove fuse 49 altogether so that it doesn't flatten the new battery again?
would removing it harm the car in any way? what else may not work?
thanks
Post #113459 16th Mar 2012 9:13pm
trafpol
United Kingdom 2006 Range Rover Autobiography Td6 Buckingham Blue
Fuse 49 runs your whole AV system and your display screen - if its out then you cant access any functions you would be able to normally. Ive taken it out a few times to hard reset the system but always put it back. When I say other functions I mean TV, radio, satnav etc,. 2006 MY Autobiography. With 'toys'
Honda ST1300 Pan European
Gone
Jaguar 3.0 SE X Type
Honda CBR1100XX Blackbird
TJF by the way for anyone who knows what that means.
Post #113477 16th Mar 2012 10:39pm
doug
thanks for that
you wouldnt like to guess at what could be draining the battery could you?
i understand my specialist not wanting to swap parts out,but i really dont want to leave it with the dealer with a blank cheque
Post #113644 17th Mar 2012 10:30pm
trafpol
Id start with the reason the dvd player doesnt work - something has gone and I would try and trace it back. Also there are a few threads on here re battery drain from FBH to faulty earths.
Finally there is more than 1 fuse that are marked radio, tv etc - should be in book or on reverse of fuse cover. 2006 MY Autobiography. With 'toys'
Gone
Post #113658 17th Mar 2012 11:42pm
