![]() | Home > Technical (L322) > EAS sensors ... can they flip over and go the wrong way? |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1456 ![]() ![]() |
I'll answer the first part of the question .... the wee arms are the correct way round on all 4 corners.
this is funny as i was taking to a retired LR technician and he told me that they had many cars in with similar faults to yours and it was caused by jacking the car up, he said that you should always have the suspension in the normal mode,ie middle setting.did you say you have been putting it through its paces V8 facelift Range Rover Autobiography 22" wheels.
There isn't enough movement in the suspension for the sensor arm to flip over |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
I notice on the Blackbox support forum that the Light Check Module (SM058) may also store the error |
Agreed - its definitely not flipped over arms.
You can see that: All 4 corners each have a linear spread which covers a similar area. This is good as the linear line shows the sensor volts are smooth through their travel and that the corresponding height output is proprotional to it. At an axle level, you can see how the left and right sensors of each axle follow a common linear line ... again, good indication of sensors are reading smoothly. The front RIGHT and rear LEFT ( yellow and pink ) have their height values at reasonable amounts ( +/- 20 to 30mm ) - but essentially they are centred near to 0, which is the standard ride height. The front LEFT and rear RIGHT ( light and dark blue ) have height values which are quite skewed away from 0. Its like their values have been biased with a -30 or -40 amount ( or more to the point, their voltage readings are biased somehow ) ... which is meaning that the ECU sees too much of a height difference and is throwing the error. My gut thoughts: The front left and rear right are definitely linked in this issue. If the 5V is common to both of them, is the ground? If the ground is not right, could that commonly affect the readings? i.e. if ground wasn't being held down to 0V properly , would that raise the sensor volt readings falsely, and this generate the wrong height settings? I think i'll pull the connectors off the sensors and make sure the pins are all clean. See what that does. V8 or else ... |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
Well I agree with daveo.
I've read of a flipped sensor on a P38 - but not on an L322 (IIRC. I suffer from CRS |
Main stealer said couldn't happen on a L322.......but then again what do they know |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Have you simply looked to see if they are the same way left to right of the vehicle? If the issue is with one side front and one side rear, check the height sensors arms look the same way round on both sides?Surely if they had flipped over they would be facing the opposite way now...
I've looked, all arms are facing the correct way.
OK - a quick update ... i with the engine running and the Faultmate showing the sensor readings live, I unplugged the front left sensor and its value went down to 0.01 and the rear right seemed to jump back to match the value of the rear left.
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 ![]() ![]() ![]() |
I got in the car today and with a loud bang the front left spring let go. I rigged up the IID Tool and got strange readings on the callibration with the left front showing callibration of +400 or so where all the others were around 150-180. Any idea why this would be?
Since it's popped back up ...
