![]() | Home > Technical (L322) > removal of tpms |
doug Member Since: 17 Apr 2009 Location: montrose ish Posts: 12 ![]() ![]() ![]() |
does anyone have any idea? are they designed to break on removal? |
hi, is the sensor not fitted via the valve hole, my brother had them on a ford he had, they are the same unit, and they were fitted through the valve and then a nut held them in place, two min job, but you need the tyre off to remove and fit. V8 facelift Range Rover Autobiography 22" wheels.
hi,thanks for your reply
coko Member Since: 13 Sep 2009 Location: ... searching ... Posts: 107 ![]() ![]() |
I would have thought that it is a few minute job on the computer. |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
The TPMS sensors seem to be EXTREMELY fragile and if the tyre fitter is a ham fisted idiot (like the ones at my supplying dealership) they will more than likely break them when replacing tyres. Discovery 4 HSE
