![]() | Home > Technical (L322) > Air Suspension Issue tonight |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 ![]() ![]() ![]() |
more than likely the big freeze!, the level system will switch off if it times out if no change is detected to stop it frying the pump etc, so you could have a bit of moisture in the air system, nothing uncommon, I am in scotland and my RR does some funny things in the winter till shes hot and the rest of the systems see the heat transfer,
ENVOY Member Since: 25 Mar 2007 Location: up a track in the middle of nowhere Posts: 239 ![]() ![]() ![]() |
similar problem with my suspension recently except it stayed in normal driving position but you couldnt adjust it, had it plugged in to clear the fault since then no problem |
itguy Member Since: 08 Dec 2009 Location: Melton Mowbray, UK Posts: 113 ![]() ![]() |
Well, codes read from the suspension ECU yesterday and the steering angle sensor had a fault stored.
SteveNorman Member Since: 18 Sep 2008 Location: somerset Posts: 17 ![]() ![]() |
A lot of these issues can be cured by updating the software in the air suspension ecu, especially on pre 2005 vehicles, as it allows the parameters to be widened before setting a fault code.
