Home > Technical (L322) > Fuel Gauge Lying?
Fuel Gauge Lying?
With my fuel gauge on the line and yellow warning light on, range left @ 20 miles, I can only get @ 80 - 85 litres into the car. I have had no change in mpg but only get @ 425 miles out of a tank (was easily getting over 500).
Anyone else got a similar problem? Or suggest a fix?
Tempted to buy 5 litres of diesel in a can and just drive until I run out of diesel, but I understand this is not a good idea? Would be interesting to see what the range computer does once I get past "0" Smile
Question .
Post #112555 11th Mar 2012 11:10pm
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
I pretty much always go past zero range as fill totally each time - about once a week at about 100 litres - and it just stays at zero range. Obviously if run to completely empty people worry about the crud being sucked up from the fuel tank but have never got this far.
What always irritates me a bit is how the range just doesnt agree with the mpg towards the end of a tank full but I guess thats just a function of the calculations being done in the computer. Hey ho
T
Post #112562 11th Mar 2012 11:44pm
the most i've ever put in with a range of '0' is 95 Litres Joe.
I'm guessing its part of a fail safe to help protect the intank low pressure pump as its known on a fair few vehicles when they run out they either overheat or get blocked with all the gunge in the tank if the system hasn't been flushed with some kind of cleaner it can be quite bad....
Take the risk Joe and when it starts to chug just pull over asap and stick your jerry can worth in. It should at least get you another 20miles Very Happy FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #112568 12th Mar 2012 7:28am
same as you joe , i can never get more than 80 odd litres in mine even when i've run with the yellow light on..
i reckon the extra fuel is hiding in the tank and pipework..kinda thing LR might do so you dont see a fullfat which has run out of fuel on the side of the road ,... ... - .- -.
Post #112573 12th Mar 2012 8:16am
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
Post #112757 13th Mar 2012 10:27am
i somehow dont think that works when you've run out of fuel on the m25 Laughing ... - .- -.
Post #112758 13th Mar 2012 10:29am
well mine again is on 0 Range and below the empty line with the warning light and warning DONG every few miles at the minute, hopefully enough to get me to the bio fuel station this afternoon on the way home Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #112766 13th Mar 2012 10:49am
So does range just stay at 0 when it gets there? .
Post #112836 13th Mar 2012 3:50pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
I have a similar problem but the opposite way.. When I fill her up, the gauge goes to full, but doesn't budge for ages after good but of driving and then all of a sudden it moves down. Weird..
Post #112838 13th Mar 2012 3:54pm
When I fill up the gauge initially goes all the way over to full, then drops back @ 1/6th. Maybe worth trying to fill up again immediately to see if there is an airlock or summat silly like that? .
Post #112868 13th Mar 2012 6:24pm
Turbo Tony
Joe, the rise and fall after fuelling may be due to the diesel frothing up in the tank. When refuelling, try pumping the last 1/3rd of a a tank slowly, to prevent the fuel churning in the tank.
At work, our trucks do this all the time.
...(This is the bit where you tell me you have a petrol!) Researching my first Range Rover purchase
Post #112877 13th Mar 2012 6:50pm
Lolo
Sounds v plausible, I'll try this next time thanks..
Post #112879 13th Mar 2012 6:56pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Shocked GaH! Thanks Emporer M Now I just lost the game...
Big Cry
FYI for all the old duffers that don't understand.
http://en.wikipedia.org/wiki/The_Game_(mind_game)
Post #112882 13th Mar 2012 7:09pm
Well is anyone else brave enough.....
Sat at a set of lights on the way to getting this....
Can anyone guess how many litres £130 got me Sad Question Question Exclamation Exclamation FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #112897 13th Mar 2012 8:11pm
Not got a scooby... Whistle
Post #112901 13th Mar 2012 8:17pm
