Home > Maintenance & Mods (L322) > which cone filter for a 2010 conversion? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35343 |
i know a man who knows...pm craig [cam-tec-craig] , he does these all the time and he will point you in the right direction.. ... - .- -.
10th Mar 2012 2:36pm |
cooper-s Member Since: 18 Feb 2012 Location: England Posts: 3 |
thanks for the response stan, i got in touch with craig however he's done loads of conversions but all diesels!
13th Mar 2012 10:05am |
13th Mar 2012 10:30am |
Why don't you put a K&N filter in the standard housing ?? First of all you have a much larger surface area and the air going in is much more laminar which aids the amount going in. The more turbulent the flow is (and cone filters do that) the less air you get in.
13th Mar 2012 11:47am |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
I would suggest the reason would be that following the conversion the standard airbox does not fit, hence the cone version |
13th Mar 2012 1:35pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Later headlamps are much deeper and sit where the original airbox is situated on a normally aspirated V8 hence the need for a cone filter...
13th Mar 2012 9:39pm |
A ha ! MY 2010 5.0 SC Galway green and sand interior!!
14th Mar 2012 8:47am |
But not on an SC model... as airbox is in another place...
14th Mar 2012 10:07am |
