Home > Technical (L322) > Do both keys work central locking together or one at a time?
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all
Had to re sync my key today and noticed that if i sync one the other doesn't work. My key was being temperamental (red light on all the time then dead) so i got my spare and found that wouldn't work so did the sync procedure and it started working. Then went back to my key after leaving it in the ignition to charge for a few mins (no light previously) and did the sync procedure to it. It worked but then i found that the spare id just set up had stopped.
It seems i can have one or the other, surely that's not right? Confused
Thanks
Carl
Post #112447 11th Mar 2012 5:42pm
You have to do both, one straight after the other
Post #112453 11th Mar 2012 5:47pm
carlos50
I think i got out of the car and locked it after one key. Has that locked out a key perhaps?
Post #112454 11th Mar 2012 5:53pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
Every time u resync ur keys u have to do the two of them at the smae time, one ater the other regardless whether one of them works, and then u have to put in ignition straight after to complete..
Post #112456 11th Mar 2012 5:58pm
carlos50
Thanks gents, havent done that so will go out and try again. Thumbs Up
Post #112459 11th Mar 2012 5:59pm
.........gents and ladies carlos .. Wink ... - .- -.
Post #112477 11th Mar 2012 6:17pm
