Home > Technical (L322) > Low Oil Pressure |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
Those pressures sound absolutely fine!
7th Mar 2012 5:24pm |
wookey Member Since: 06 Feb 2012 Location: UK Posts: 5 |
That's brilliant thanks Simes.
7th Mar 2012 8:20pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1367 |
Ok - if the switch is ok / new and the pressure is OK ( measured independently ) then maybe worth looking at whether the switches signal is reaching where its meant to go?
7th Mar 2012 8:33pm |
A friend put his Snap-on computer on and looked at the pressure switch and you see it change on/off.
7th Mar 2012 8:41pm |
Even though it was only serviced less than a 1000 miles ok, do you think it's worth doing an oil and filter change?
10th Mar 2012 10:33am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35327 |
just wonder if the garage did fit the correct filter and like you say, the correct oil....the oil specs for the range are on the wiki and with that info in hand , talk to the garage.. ... - .- -.
10th Mar 2012 11:01am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Have you considered the low oil pressure may be connected to the themostatic valve serving the oil cooler? |
10th Mar 2012 11:08am |
11th Mar 2012 7:51pm |
