Home > Technical (L322) > Suspension Inactive HDC Inactive
Tesh
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Well what can I say!!!
Brake caliper replaced and working perfectly but now I have a dash that looks like the "Vagas Strip"
The car drove fine for about 20 miles then Suspension Inactive, HDC Inactive faults flashed up along with 2 orange brake lights and the DSC triangle light. The suspension locks in normal height and wont lower or raise
When I switch the car off and re start the lights have gone out and the suspension works but as soon as I move off the lights and warnings come back on.
The battery is brand new, so it cant be that
I have an EAS Activate dongle and the code reads "Can Bus Fault"
Anyone got any ideas?
Post #102233 18th Jan 2012 12:43pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Check wiring in area of hub, may have dislodged during caliper replacement.
Mine had worn through on inside of tyre, worth a check.
Post #102239 18th Jan 2012 1:12pm
Dolphinboy
check your ABS sensors - the reason you get all the lights is that the ABS is central to the CAN BUS and if triggered, sets off all the other sensors as they cannot be read. Mine had the same prob but cleared itself when I changed the wheels - check for worn wiring around the ABS sensor on the wheels.
Post #102272 18th Jan 2012 3:28pm
Vogue
disconnect battery, leave for 15 mins and re-connect, mine did exactly the same - suspension fault a reset seemed to cure it.
Post #102274 18th Jan 2012 3:33pm
Diver Bryn
United Kingdom 2005 Range Rover Vogue Td6 Tonga Green
Likewise disconnecting battery negative terminal only for 15 minutes resets the computer. Need to also turn steering lock full turns left and right then drive vehicle for 100 metres error code returns to normal. Diver Bryn
Previous Transport:
Honda CB250n
Toyota Starlet
Renault Fuego 2 ltr TX
Fuego Turbo
BMW 528i
Escort RS Turbo
Capri 2.0 L Ghia
Kawasaki GT750 P4
Mini Metro
Ford XR2
Volvo 740 TDi Estate
Mondeo Tdi
Volvo V70 Tdi
Mercedes E300 TDI
Mercedes E320 Cdi
Mercedes S320 Cdi
Land Rover Discovery 3 TDV6
Mini Cooper Diesel
Mercedes Vito Van 111
Range Rover TD6
VW Golf 2ltr GTD 2015 Year
2016 Audi Q7 Sline 3ltr 272Bhp
Post #103021 22nd Jan 2012 9:35pm
Tesh
It seems to have settled down and hasnt reoccurred
So fingers crossed Thumbs Up
Post #103023 22nd Jan 2012 9:50pm
This has just come up on mine Sad
I hadnt waited for the glowplug light to go out and cranked too early by accident and then ran the front and rear window heaters and seat heaters and steering wheel and as the standard battery I have is only 90ah I think I killed it again Sad
Just Soing the 15minute reset now but guess I may be writing a new battery sooner than I thought Sad
It did say -3 on the dash though when I got in and I already flattened it a week or so ago while washing the car and swapping the wheels over DOH!!
Fingers crossed the reset works as I have to get to brum this morning!!! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #111123 6th Mar 2012 8:34am
What's your username again ...... Laughing
Post #111145 6th Mar 2012 10:05am
Ha ha Very Happy
I wasnt looking as i started it leaning over from the passenger side and was going to carry on loading the car but when it didn't catch straight away i leaned over a bit more and waited for the light to go out.
Then put the heaters on and demisters and put some more kit in the car and then drove off but after about a mile it went DING DONG!
I hate that ruddy noise!
well guess i'll go pump ECP for a 110ah jobby if it happens again as im sure it will! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #111180 6th Mar 2012 12:57pm
dont forget the discount codes.... Thumbs Up ... - .- -.
Post #111198 6th Mar 2012 2:26pm
