Home > Maintenance & Mods (L322) > Convert Fogs to DRLs ?
Page 2 of 3 <123>
yes you can, but only up to 2005 ranges.... ... - .- -.
Post #111013 5th Mar 2012 3:50pm
mjdronfield
Ah, there is a mix of cars, from looking at the posters on this thread, but Joe90 has a 2002 model, according to his signature ;
Range Rover 2002 TD6 HSE Alveston Red, Sand Leather
So he could use Navcoder ?
I know he'd have to get a lead and the registered software, but for less than £45 he could change his light settings to his hearts content....
Amongst all the other things he'd have access to.............
Cheers
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #111024 5th Mar 2012 4:18pm
i pretty sure joe is aware of the navcoders ability's mark... Wink ... - .- -.
Post #111025 5th Mar 2012 4:27pm
I have navcoder Very Happy
Not played with the DRL function, didn't see an option to make the fogs work as DRL's though which was the object of the exercise, but might be tempted to get the main beams running at 50% as well (can I do both at the same time Question ) .
Post #111098 5th Mar 2012 9:45pm
pretlove
I'm thinking of putting angle eye style led rings in my headlights and just having them as drl's
I've seen it done on the sport forum and it looks ok Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #111111 6th Mar 2012 12:01am
this might be of interest to you lee.....
http://www.disco3.co.uk/forum/topic73755.html?highlight ... - .- -.
Post #111133 6th Mar 2012 8:33am
Am struggling to find 50 ohm resistors - don't know what I am looking for exactly. Most on ebay seem to be for GHD hair straighteners - don't need that as mine are working OK Smile
Sorry to be a dunce Rolling Eyes .
Post #111152 6th Mar 2012 9:40am
my bad joe Embarassed ..its been over a year since i fitted mine and its 50 watts not 50 ohms.....
http://www.ebay.co.uk/itm/50W-6ohm-Load-Re...27bd59e1f5 ... - .- -.
Post #111159 6th Mar 2012 9:51am
Hopefully final dunce question, do I need one resistor for each lamp?
and also
Had a poke about in the engine bay to find the wiring which all seems buried under the headlight or down in the bowels behind the bumper. Where did you tap in to the wiring, and is there a straight forward live ignition feed and a headlight feed there together somewhere? .
Post #111173 6th Mar 2012 11:06am
yep, one for each wire ending....
i disconnected the headlight plug and stuck a multimeter on it and found an ignition and the headlight feed . i then just split into those wires feeding the plug.. ... - .- -.
Post #111196 6th Mar 2012 1:19pm
Thanks for all your help Stan.
Once I have all my bits and bobs I'll turn this thread on its head with a photo howto Smile
LEDs arrived today from.......California Wink .
Post #111215 6th Mar 2012 3:42pm
looking forward to the pics joe.... Laughing ... - .- -.
Post #111216 6th Mar 2012 3:43pm
Foglight Overhaul Howto
Here's some for starters
http://www.fullfatrr.com/gallery/thumbnails.php?album=455
Having trouble finding the headlight wiring (and the time to do this drl job) .
Post #114740 25th Mar 2012 1:32pm
supershuttle
What's the advantage of DLRs over the normal lights - are they actually brighter?
Because I was thinking if it's good for the front, it must be good for the back - so just have your lights on all the time.
I bet I'm missing something, like I am with all the effort, time and cost that goes in to changing normal bulbs to LEDs - although I did do my pathetic sidelights Very Happy Geoff
Post #114793 25th Mar 2012 10:02pm
Not expecting them to be any brighter, but definitely whiter !
Using the little drl dongle I don't have to think about switching anything on they'll just come on when I start the car (like an old Volvo Wink) As mentioned in a previous post, I could use Navcoder to get the headlights to do drl, but that's no fun Smile
You do have a point about rear lights though. In the recent fog I have seen many bozos coming in my rear view mirror with just their fancy drls on, then once they pass me, they just disappear into the fog !
I think its a man/car thing, proper drls are only at the front, so you have to make yours do the same Smile .
Post #114804 26th Mar 2012 12:02am
Page 2 of 3 <123>
