![]() | Home > Technical (L322) > Air con valves |
It will be the only one that the device can connect to as they use different industry standard sized valves IIRC |
You connect to number 2 on the diagram.
nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 233 ![]() ![]() ![]() |
Thanks guys - the two caps appear to be identical with a small triangle embossed on the top with an image of a valve. On my car (2005 Vogue 4.4) the valves are not in the same position as the diagram either! I'll try and post a picture later but it's chucking it down with rain at the moment. But the diagram might help me decide as the pipework seems to be different sizes. (No doubt raining on kingpleb as well seeing as I'm in the Rotherham area as well!) |
90% of the time, top up kits are a waste of time and money - not to mention bad for the environment.
I'm doing my bit for the environment - I bought a second hand car, and converted it to LPG, which means I can save the world an enormous amount of electricity by not using a cash dispenser quite so often! |
I agree with SteveMfr on this, diy top up is not really to be recommended, you simply don't know how much refrigerant you are adding to a system you don't know the contents of. You might as well throw the gauge away for all the good it is.
Compressors seem to be about £300 from indies - several people have posted on here about how good kwiFit's service has been when they've used it, and there are plenty of other service agents about. |
L322Pilot Member Since: 10 Feb 2011 Location: Solihull Posts: 19 ![]() ![]() ![]() |
Just had my Condenser replaced due to a leak and although the job is fairly strait forward for DIY I think the regasing is best done by a quallified person. I had the job done at a LR main dealers where they charged for 2.8 hours labour and although this is probably way more expensive than a Indy garage I do feel a certain peace of mind. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35490 ![]() ![]() |
^^^^ as above, i fitted my condenser and had it re-gassed properly.. ... - .- -.
Just a quick update - got the kit and couldn't resist using it. Put the valve on and seemed to be very little pressure in the system so I used the canister of gas (environmentally friendly not R134) and the compressor kicked in instantly and I now have lovely cups air from the vents! The gas has a dye in it so I will have a look for leaks.
Do you need an ultra-violet lamp to spot any leaks as with normal dyes? |
yes... |
Yes and fortunately I have one. Phew! |
