Home > Maintenance & Mods (L322) > After market reversing camera?
DaveAngel
2015 Range Rover Vogue SE SDV8 Barolo Black
Been thinking about buying an ebay reversing camera
http://www.ebay.co.uk/itm/CCD-Rear-View-Re...3a6e50b3ad
Appreciate its for the sport. My 2005 isn't fitted with one, does that mean there is no loom\fitting and i'm waisting my time?
Saw this WIKI entry which could help me, assuming the bits are there..
http://www.fullfatrr.com/forum/topic4621.html
Worth investigating? __________________
2015 FFRR SDV8
2011 FFRR TDV8 4.4 - Gone
2005 FFRR TDV6 - Gone
Post #110416 1st Mar 2012 10:28pm
That one won't fit in the licence plate fitting.
You might need the video lead from toysformycar
But not sure of the wiring to make it work when you go into reverse.
Check my carpc project thread. I fitted one like this.
http://www.fullfatrr.com/forum/topic8786.html .
Post #110417 1st Mar 2012 10:33pm
DaveAngel
Joe, your a total ledge!
Not sure how i missed that thread, love the VBS. Will read in detail tomorow. __________________
2015 FFRR SDV8
Post #110422 1st Mar 2012 10:52pm
Range
United Kingdom 2010 Range Rover Autobiography Black 5.0 SC V8 Java Black
aftermarket camera
I have a aftermarket reversing camera (the camera sits next to the rear wiper but unless i tell people its there they dont see it as the camera is so small!) (about x3 times smaller than the standard one) which i picked up for £17 from lightinthebox.com and then had it fitted by installers as I wanted it to look and be installed like it came with the car!! the install cost £60 so 3 times more than the camera but they soldered connections for a propper fit and i bought the cable with reversing camera input from toysinyourcar £35 job done the only 2002 Vogue i know with reversing camera CCD with night vison very good camera! Thumbs Up A Rangerover is for life not just for christmas
L322 5.0 Supercharged Autobiography - Black
L322 5.0 Supercharged Autobiography - Black - gone
L322 4.4 Vogue Green - gone
P38 4.6 Vogue Blue - gone
P38 4.6 HSE Grey - gone
P38 4.6 HSE Green - gone
P38 4.0 SE Blue - gone
Post #110559 2nd Mar 2012 5:33pm
DaveAngel
looked at the toys on your car lead, and it doesn't do MOST (05>) systems, will look around and see whats about. __________________
2015 FFRR SDV8
Post #110581 2nd Mar 2012 7:00pm
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Im looking to install mine this weekend, i also have the cable with various inputs and outputs including the Reverse camera input all i got to do is add a negitive input for the wires to be complete
When the spoiler is off is it straight forward running the cable into the car??
thanks
Neil
Post #112952 13th Mar 2012 11:24pm
cliffy
I have looked at the wiki and searched but didnt find the answer i was looking for
Post #112954 13th Mar 2012 11:25pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Hey Neil,
The standard camera goes thru the grommet into the body of the car above the head lining it then loops round to the right and down the D pillar into the area behind the right cubby hole.
Nothing to stop you routing a more direct way to the front screen.
Good luck. Hoping to get my factory cam sorted and do write up this weekend!
Post #112956 13th Mar 2012 11:30pm
Range
Hi Cliffy
No its a very tight fit trying to route the cable the way you have said I got mine installed as i just could not be bothered with all the hassle! cost £60 job done they cut the end off then treaded it through the hole in spolier and then soldered the ends back on and its a very nice and neat job they did
If you have a vogue all your electronics are in the boot on left hand side so no point routing anywhere else!!
if HSE or SE then yes you will have to route cable all the way to front of you RR
I would also say the cable that comes with the camera proberly isn't long enough (power cable that is!!) so if doing it yourself make sure you measure out the cable first before as nothing worse than finding out half way through!! A Rangerover is for life not just for christmas
Post #113031 14th Mar 2012 1:43pm
tanertimur
England 2005 Range Rover Vogue Td6 Java Black
iv bought a reverse camera (number plate one) cheap on flea bay but good. it tilts to an angle of your choice and good picture at night too. Iv fitted this to a gvif interface and the camera comes on when ever i put car in reverse.
benefit of gvif interface you can also add 3 other AV devices to it. Range rover td6 54 reg touch screen
Post #113342 16th Mar 2012 12:14pm
twhincup
tanertimur was it 1) how cheap for the camera and interface and 2) easy fitting for a non-electrician? 2007 3.0L Diesel VW Touareg SE
2003 4.4 LPG, Vogue, Silver
Post #113396 16th Mar 2012 4:03pm
daveo
the only gvif interface i have looked at are quite Pricey at around £150, what have you got Question V8 facelift Range Rover Autobiography 22" wheels.
Post #113413 16th Mar 2012 6:13pm
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
Could someone give a little detail as to the replacement of the original reversing camera as I get nervous that it might be fibre optic wiring from it? Basically what is involved in replacement without rewiring right back to one of the boxes in the rear left by the tv tuner etc? In fact which box is it!?
Basically can someone please just do mine while I am in bed and so i dont need to!
Cheers guys
Post #113414 16th Mar 2012 6:15pm
daveo
not sure what year your car is but up 2010 they are a standard camera 12v 2pin plug with a coaxial for the video after that they go to HD cameras but still a coaxial but they have a 4pin connector insteed of the 2pin. V8 facelift Range Rover Autobiography 22" wheels.
Post #113441 16th Mar 2012 8:08pm
tomthevet
Mine is a 2006. And without having removed my camera to see what the problem is (I imagine its maybe full of water?) is it a matter of pulling it through a little way and snipping the wires and soldering in new non OE camera or is it easier to get a camera with a long enough cable to pull through to the original connection somewhere in the left rear corner of the car? (touchscreen car)
T
Post #113447 16th Mar 2012 8:25pm
