Home > Maintenance & Mods (L322) > My experience of a Td6 remap |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
Great write up. I agree that it is one of the best things you can get done to the Td6. I was lucky that mine had it carried out by a previous owner. It makes the Td6 nimble, smooth shifting and sporty (for a Range Rover). Tom
1st Mar 2012 1:47pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
if you're talking about a company called rapid remap , then my experience was the opposite .... |
1st Mar 2012 2:33pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Stan you should go back to them as model specific tunes do not necessary suit every car of the model they are designed for . I'm pretty sure if they are any good they will have a number of maps for the TD6 one of which will suit your specific car. Present :2008 TDV8 HSE
1st Mar 2012 2:58pm |
it was a while ago now googsy and tbh i lost confidence in the company ... |
1st Mar 2012 3:05pm |
benjj Member Since: 27 Feb 2012 Location: North Yorkshire Posts: 116 |
I'm not absolutely positive it was Rapid Remap, my local indy (who has done a lot of these and is well regarded) told me ages ago who he used. It could have been another supplier and I'm just remembering wrong. I'll double check who the map was done by.
1st Mar 2012 4:22pm |
i just wonder how difficult it is to do these remaps.....plug into the obd port, connect to software on laptop, play with settings and then upload back to car..
1st Mar 2012 4:24pm |
Yep, I don't think the actual upload/change is any kind of work at all. As for writing the map itself, I really don't know. |
1st Mar 2012 4:27pm |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
As you demonstrate Stan - that's the easy (and cheap) bit. It's the cost of a Dyno to test the setup and access to the maps in the first place - and then the skills to tweak them correctly - and not (like some places) just upping the fuelling and boost pressure and hoping for the best. |
1st Mar 2012 4:28pm |
didnt have a dyno test when i had mine done ....they did say that they tweaked my map but i wonder if there's standard maps for performance .economy etc... |
1st Mar 2012 4:34pm |
1st Mar 2012 4:37pm |
I thnk I'd rather have it done on a dyno - then the maps can be tweaked to suit the car and results of the map changes tested and proven! |
1st Mar 2012 4:39pm |
funny enough my re-mapper said the same thing except for more mpg rather than performance.. |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
I've read these type of 'tuning' posts for a while with a 'shall I or shan't I' outlook - but weighing things up about the fragility of the TD6 gearbox i've decided against going down that route |
2nd Mar 2012 4:43am |
Yep, I can understand that.
2nd Mar 2012 7:51am |
