Home > Technical (L322) > Error code 30 air quality sensor line fault
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
This came up on iid tool. What is it? Question ta
Post #110077 29th Feb 2012 1:17pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Air Quality Sensor is (I believe) in the Climate Control system - it tells the system to recycle air in the car when the pollution levels outside are high, if you have the recycle button pressed to select the auto position.
Post #110083 29th Feb 2012 1:39pm
Lolo
Thanks, makes sense, so any ideas how hard it is to get into the climate control if I wanted to replace the sensor?
Post #110086 29th Feb 2012 1:43pm
Simes
If this has worked(!) it's item number 7 - looks easy enough..... But looks can be deceptive!
Post #110089 29th Feb 2012 1:58pm
