Home > In Car Electronics (L322) > Remote Central Locking and Key Fob issues
filthyliam
Hi all
I have just had to fit a new battery to my 4.4 '54 plate everything now works and has re set clock steering date etc but i am now having to lock the car via the key also the boot release wont work. All the buttons on the remote flash but no action!. I was wondering I have done something wrong when replacing the battery but when the old one went flat the remote packed up when I jump started it and hasnt worked since.
I didnt want to change the battery in the fob as i thought I may have to re programme the remote and cant find the details on here how to do this
has anyone any ideas what maybe causing this could it be the battery in the remote or is it co incidence that both batteries have gone at the same time?
thanks in advance
Post #109595 27th Feb 2012 10:26am
simon1233
Have a look here
http://www.fullfatrr.com/forum/topic3713.h...rogramming
Simon
Post #109597 27th Feb 2012 10:30am
filthyliam
Thanks for this
will I have to re programme the key like this if I change the battery in the remote?
Post #109601 27th Feb 2012 10:34am
liam, perchance did you have the key in the ignition when you changed the battery..
Post #109607 27th Feb 2012 11:07am
filthyliam
no why?
(didnt say to on the instructions)
Post #109621 27th Feb 2012 12:50pm
reason i ask is that you should take the key out when dis/reconnecting the battery which you did..keeping the key in might have causeed your problem..
Post #109632 27th Feb 2012 1:21pm
filthyliam
Thanks for this Stan will I have to reprogramme the fob if I just change the batteries ?
Post #109635 27th Feb 2012 1:36pm
not sure liam, there are a few threads on this , try a search or hopefully someone will come along and help..
Post #109639 27th Feb 2012 1:47pm
simon1233
When my alternator packed in both keys needed recoding, but other times when I have disconnected the battery (one occasion for more than 2 hours) I haven't needed to recode the keys - go figure Idea
Post #109666 27th Feb 2012 4:00pm
filthyliam
thanks for this Simon have you or anyone else had to change the batteries in the remote if so did you need to reprogramme ?
Post #109750 27th Feb 2012 6:56pm
simon1233
Not needed to change the battery in the remote, but I would imagine that this would not require a re-code as the key would still transmit on the same frequency?
Possibly someone better informed will be along to confirm/correct this later...
Post #109788 27th Feb 2012 8:27pm
I've changed many batteries in many car remotes and have never had to reprogram the fob.
It's very possible your fob batteries just died. I've found that they tend to go suddenly and without warning.
I'm also guesing that the key is coded to the ignition? So a duff key won't activate the ignition even though the key fits? If this is the case, then you shouldn't be able to switch the engine on. I assume you can?
That said, I've never (yet) changed the batteries in a RR remote. Si. <This is my name.
Post #109848 28th Feb 2012 6:35am
filthyliam
thanks for this
the light is still flashing on the remote when you press any of the buttons its just it isnt operating anything
anyone else had something similar ?
Post #109916 28th Feb 2012 1:41pm
duckworthparts
Site Sponsor
was the motor unlocked at the time of changing the battery in the remote? how long did it take for you to change the battery over? You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #109920 28th Feb 2012 2:02pm
filthyliam
I havent changed the battery in the remote yet why ?
Post #110045 29th Feb 2012 9:55am
