![]() | Home > Technical (L322) > Hot Diff and Leaking Diff Breather |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 ![]() ![]() ![]() |
When my car was serviced I asked them to double check the front diff, as ever since I had the front driveshafts replaced (as part of the Range Rover Assurance Programme) it had developed a leak -which had subsequently been fixed a few times by the dealer. |
I saw this on the 'other' forum, need to check mine but wonder if this is my issue?
Coz the simple and easy route is not obvious to the |
jope Member Since: 04 Apr 2009 Location: Reinsvoll Posts: 43 ![]() ![]() ![]() |
RRUK, did you find the problem causing the diff oil leak? |
Jope, not really it seemed to stop. I suspect the breather was the issue, there is an LTB about the positioning of the breather pipe.
is it leaking from the breather pipe in the engine bay? Discovery 4 HSE
it's been to cold so I haven't been investigated to much.
